The following error message appears in the Plesk interface or during Plesk migration process:
Unable to connect to database: Too many connections
SQLSTATE[08004] [1040] Too many connections
ODBC error #HY000: [unixODBC][ma-3.0.8]Too many connections
Websites fail to load with the error:
Error Establishing a Database Connection
Plesk license installation fails with the error:
Incorrect ServerInfo format (Error code: 2)
exit status 1
The maximum number of simultaneous connections to the MySQL server has been reached and new connections to the server cannot be established.
Note: On Linux server with MySQL installed, the max_connections
limit cannot be higher than 214, unless the solution from this KB article is applied.
# Automatic Solution
Download the script that will set the MySQL parameter
max_connections
to 300:# wget https://raw.githubusercontent.com/plesk/kb-scripts/master/mysql-max-connections/mysql-max-connections.sh
Make the script executable:
# chmod +x mysql-max-connections.sh
Execute the script:
# ./mysql-max-connections.sh
Note: If the automatic solution did not help, apply the manual solution below.
# Manual Solution
Find the current
max_connections
value:# plesk db "SHOW VARIABLES LIKE 'max_connections'"
| Variable_name | Value |
| max_connections | 151 |
Open the MySQL configuration file
my.cnf
in a text editor. In this example, we are using the vi editor:-
on CentOS/RHEL-based distributions
# vi /etc/my.cnf
on Debian/Ubuntu-based distributions
# vi /etc/mysql/my.cnf
Increase the number of connections by adding this directive under the
[MySQLD]
section:[mysqld]
max_connections=300 -
Save the changes and close the file.
Restart MySQL/MariaDB service to apply the changes using one of these commands:
# service mysql restart
# service mariadb restart
Connect to the Plesk server via RDP.
%plesk_dir%Databases\MySQL\my.ini
in a text editor. -
[MySQLD]
section (the default value is 300):[MySQLD]
Restart the MySQL/MariaDB service Plesk Management Service using Windows Plesk Services Monitor
4 comments
Hi @Yassir Elnaw,
As far as I understand, in your situation 'too many connections' issue was caused by some malware running on the server.
Thanks for sharing your solution, I think it might come in handy for someone else.
I'm having this issue right now on my OVH VPS server.
I tried the solutions you give on this page but it didn't work, when i try to display the current
max_connections
value, the same error appears :"ERROR 1040 (HY000): Too many connections
exit status 1"
what else can i try ? I'm a beginner in server administration and i'm affraid that if i restart the server while the error is still here it could lost data on restart...
[EDIT] : OK, so i managed to find the my.cnf file wich was not located in the same file as indicated here. I've put a higher max-connection value and was able to reconnect my Plesk admin.
The problem was caused by too much disk space used in my case and running :
apt-get clean
allowed me to free a little disk space and regain access to the Plesk Admin. Hope this can help some of you here.
Warning : If you encounter the same problem as me (disk space), i highly recommend to free more disk space as soon as you get your Plesk admin access back to avoid this problem to happen again...
@Francois-Xavier de Crevoisier thanks for sharing!
