- Plesk 12.0 for Windows
Note: This article has the reference to the issue with the fix available:
- #PPPM-2740 "Plesk would sometimes send out notifications warning of MySQL and MSSQL soft limits being exceeded when there was actually no overuse."
Fixed in:- Plesk 12.5.30 31 August 2015 (Linux)
Getting over usage e-mail notifications by Plesk:
The `<domain.tld>` subscription, owned by user `<username>`, is approaching or already exceeded the resource usage limits:
Total MySQL databases quota: 5 GB limit / 882.7 MB (17%) used / 4237.3 MB (83%) remaining
when actually there is no overusage.
This issue has been considered as software issue #PPPM-2740 . It was fixed in Plesk 12 microupdate #44 .
For Plesk 12 apply the latest Plesk microupdates .
As a workaround replace the file
%plesk_dir\\%admin\\plib\\Limits\\Limit\\DatabaseDiskSpaceAbstract.php
with one in
pppm-2740.zip
archive.
