If Plesk Firewall is enabled, rules manually added in CLI are removed
2 comments
    Sid B
    I am sysadmin and root - but the Plesk > Tools & Settings > Firewall  does NOT work. "Firewall" is nOT listed there. In fact, the search function for 'firewall' does NOT tell you where how/to do this.?
    Plesk Parallels ver 12.5 on a Centos 7 dedicated server.
    • OS: CentOS Linux 7.4.1708 (Core)
    • Plesk version: 12.5.30 Update #76 , last updated at July 20, 2018 03:44 AM
    Sid
    Ivan Postnikov
    Hello @Sid,
    Most probably this means that "Firewall" is not installed.
    It may be installed at Tools & Settings > Updates and Upgrade > Add and Remove Product Components > Plesk extensions > Firewall
