Websites shows 502 Bad Gateway or 404 Not Found errors while Apache is running properly
Created:
2016-11-16 13:02:24 UTC
Modified:
2017-06-22 16:22:44 UTC
15
Have more questions?
Submit a request
  • Plesk for Linux
  • Websites show the 502 Bad Gateway or 404 Not Found errors, but the files exist.
  • Website show 502 Bad Gateway when trying to connect over HTTPS or redirect to other site.
  • Apache process is running.
Web server configuration files are corrupted or absent, or module is not loaded.
  • Disable Nginx service:
  # /usr/local/psa/admin/bin/nginxmng --disable
  • Move all vhost's config files from /etc/nginx/plesk.conf.d/vhosts to a temporary directory:
  # mkdir /root/support_plesk && mv /etc/nginx/plesk.conf.d/vhosts/* /root/support_plesk
  • Enable Nginx service:
  # /usr/local/psa/admin/bin/nginxmng --enable
# /usr/local/psa/admin/bin/nginxmng --status
Enabled
  • Or using Plesk UI:
Go to Plesk > Tools & Settings > Services Management
Click Stop on Reverse Proxy Server ( nginx ) and then Start .
  • Make sure that cgid Apache Module is enabled in Plesk > Tools & Settings > Apache Web Server.
2 Comments
