Unable to send an email using the STARTTLS authentication:
CONFIG_TEXT: 454 4.7.0 TLS not available due to local problem
The following error can be found in the
/var/log/maillog
file:CONFIG_TEXT: postfix/smtpd[26508]: warning: cannot get RSA certificate from file /etc/postfix/postfix_default.pem: disabling TLS support
postfix/smtpd[26508]: warning: TLS library problem: 26508:error:02001002:system library:fopen:No such file or directory:bss_file.c:355:fopen('/etc/postfix/postfix_default.pem','r'):
postfix/smtpd[26508]: warning: TLS library problem: 26508:error:20074002:BIO routines:FILE_CTRL:system lib:bss_file.c:357:
postfix/smtpd[26508]: warning: TLS library problem: 26508:error:140DC002:SSL routines:SSL_CTX_use_certificate_chain_file:system lib:ssl_rsa.c:722:
TLS misconfiguration in Postfix:
The
postfix_default.pem
certificate file does not contain the valid SSL certificate or it is broken. -
The path to the certificate is incorrect in the
/etc/postfix/main.cf
file. -
TLS configuration parameters are missing in the
file.
Go to Tools & Settings > SSL/TLS Certificates.
Click the Change link opposite the Certificate for securing mail option:
Specify the correct certificate in the Select Certificate drop-down menu.
Press the OK button to apply changes.
If the issue still persists, compare the current configuration with the steps from the "via SSH" section and fix the configuration if it is required.
Create the
/etc/postfix/tls
directory, set correct ownership, group, permissions and create a certificate file:# mkdir /etc/postfix/tls
# chown root:postfix /etc/postfix/tls
# chmod u=rwx,go= /etc/postfix/tls
# cd /etc/postfix/tls
# openssl req -new -x509 -nodes -out smtpd.pem -keyout smtpd.pem -days 3650 -
Change
accordingly:CONFIG_TEXT: smtpd_tls_CAfile = /etc/postfix/tls/smtpd.pem
smtpd_tls_cert_file = /etc/postfix/tls/smtpd.pem
smtpd_tls_key_file = /etc/postfix/tls/smtpd.pem
smtpd_tls_session_cache_database = btree:${queue_directory}/smtpd_scache
smtpd_tls_security_level = may
smtpd_use_tls = yes
smtp_tls_security_level = may
smtp_tls_CAfile = /etc/postfix/tls/smtpd.pem
smtp_tls_cert_file = /etc/postfix/tls/smtpd.pem
smtp_tls_key_file = /etc/postfix/tls/smtpd.pem
smtp_tls_session_cache_database = btree:${queue_directory}/smtp_scache
smtp_use_tls = yes
smtpd_tls_received_header = yes
smtpd_tls_ask_ccert = yes
smtpd_tls_loglevel = 1
tls_random_source = dev:/dev/urandom -
If the
smtpd_sasl_auth_enable = yes
option is set in the/etc/postfix/main.cf
file, make sure that thesaslauthd
service is started:# service saslauthd status
Reload Postfix configuration:
# service postfix restart
