ModSecurity: Found another rule with the same id
5 comments
    dither
    It was my mistake. I misunderstood the modsecurity's whitelist syntax.
    I thought by adding id:210280 that it would whitelist the IP for that particular rule's ID instead of being just the whitelist rule's ID.
    Everything works fine with comodo rules in Debian 9.5.
    Alexandr Redikultsev
    Hello, @dither!
    I am glad that it's sorted out, thank you for sharing!
    Hello, @dither!
    The bug in the article describes the issue that occurs regularly on any attempt to use ModSecurity, so I believe that the issue you are facing is having a different root cause.
    In order to troubleshoot it, I suggest the following action plan:
    1. Temporary switch ModSecurity to another rule set, for example Atomic Basic.
    2. Disable ModSecurity.
    3. Enable it back with Atomic Basic.
    4. Switch the rule set back to Comodo ModSecurity (subscription).
    dither
    This problem also occurrs on Plesk Onyx 17.8.11 / Debian 9.5 with Comodo ModSecurity (subscription).
    I was trying to whitelist one ip such as:
    SecRule REMOTE_ADDR "^192\.168\.1\.1$" phase:1,id:210280,nolog,allow
    Plesk also reports the same error:
    "Invalid ModSecurity configuration: AH00526: Syntax error on line 1 of /etc/apache2/plesk.conf.d/modsecurity.conf: ModSecurity: Found another rule with the same id".
    Strangely modsecurity.conf file is empty.
    Integrator
    Bug #PPPM-3733 have been fixed in Plesk 12.5.30 Update 25
