- Plesk Onyx for Linux
Transparent or solid color background areas of the "Banner" module became black after website publishing in Web Presence Builder.
A new method of website generating during the publication: the original image file can be converted (re-sized and cropped) in order to fit web page area, where it is to be placed. It is a Web Presence Builder bug PPB-4315.
A a workaround, use "Text & Images" module instead of the "Banner" module.
Or replace converted image file (for example
/var/www/vhosts/example.com/httpdocs/attachments/Header/published_image_4.png
) with the original one.
