If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Unable to send mail via SSL: warning: TLS library problem: 31990
4 comments
    Plesk
    #plesk repair mail
    Repairing the mail server configuration
    Reconfigure all domains and mailboxes? [Y/n]
    What will be reconfigured and will the mailboxes and messages be retained?
    Ekaterina Babenko
    Hello,
    You can check what plesk repair mail utility from the the following link to our documentation:
    https://docs.plesk.com/en-US/onyx/administrator-guide/plesk-administration/plesk-repair-utility/plesk-repair-utility-mail.74652/
    The messages from the mailboxes will not be removed by running the utility.
    frederic bigot
    Hi
    I am facing the same problem but repair mail doesn't work.
    I have installed let's encrypt on webmail, and since then I can't send email using PHPMailer (SMTP connect error)
    maillog says :
    SSL_accept error from localhost.localdomain[127.0.0.1]: -1
    warning: TLS library problem: 27872:error:140760FC:SSL routines:SSL23_GET_CLIENT_HELLO:unknown protocol:s23_srvr.c:640:
     lost connection after STARTTLS from localhost.localdomain[127.0.0.1]
    it works fine on another server on which I didn't secure webmail. So I think the problem comes from let's encrypt
    Anzhelika Khapaknysh
    @frederic bigot,
    I would suggest contacting our Technical Support Team for assistance, so they can check the issue in details.
