Hardware changes are not reflected/updated in the Plesk Health Monitor
9 comments
    Peter Debik
    According to Obsidian documentation, the hardware changes must be entered in Grafana manually. However I was not able to find any option in their GUI configuration or configuration file where such hardware changes could be entered. Asking here because of this forum thread that brought up the issue that after a swap size change that change is not reflected in Advanced Monitoring:
    https://talk.plesk.com/threads/problem-with-swap-after-changing-size.354616
    Ivan Postnikov
    Hello Peter Debik,
    Advanced monitoring is based on Grafana.
    To update hardware parameters in Advanced monitoring:
    1. Log into Plesk
    2. Navigate to Extensions > My Extensions > Grafana
    3. Press on the Restart Integration button.
    1
    Peter Debik
    I try to find a "Restart Integration" button, but cannot see that anywhere. I am logged in as server admin, went to Extensions > My Extensions > Grafana. I see an "Open" button and a "More" button. When I click "More", I can select "Remove" and "Disable".The "Open" button leads to a page where I can "reload" the integrations (which does not really do anything at the moment) and also have "Open application" which brings me onto the Grafana page.
    But no "Restart Integration" button.
    Maxim Krasikov (Edited )
    Hi @Peter Debik,
    Button Restart Integration should be available after opening Grafana extension.
    If the button is not available, but hardware changes are still not updated, please contact Plesk support for assistance:
    Peter Debik
    Thank you vor getting back to me on this. So obviously the question to support needs to be why in a totally clean Plesk default installation of Obsidian the button is missing:
    I would not want to buy support for this case, because this is still a test server and clearly a bug as it is a a fresh Plesk installation on a fresh dedicated server. I'll then rather wait until it is detected as a bug by Plesk and solved in a micro update.
    Peter Debik
    According to a user's comment in
    https://talk.plesk.com/threads/problem-with-swap-after-changing-size.354616/#post-870701
    the button only shows when hardware changes have been detected. So obviously Grafana auto-detects changes, but then you need to click that button to tell it that it's right and the changes shall be applied.
    Solved.
    Denis Bykov
    Peter
    Thank you for sharing these details.
    Jorg
    What if the auto-detect doesn't work? I doubled my disk size, but this button doesn't show.
    Ivan Postnikov
    Hello Jorg
    There's a possibility that the filesystem wasn't resized after adding the disk space.
    Consider contacting the server provider to check this.
