Scheduled domain level backups rotation does not work - backup files are not being deleted
Created:
2016-11-16 12:59:29 UTC
Modified:
2017-08-16 16:58:31 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Linux
  • Plesk 12.0 for Linux
The scheduled domain level backup rotation does not work. Backup files are not being deleted automatically.
This behavior is considered to be a software issue. The issue was fixed in Parallels Plesk 11.5 #MU 42 . The internal request ID is PPPM-1556 .
Please update Plesk to the latest avaliable microupdate in order to fix the issue. If for some reason you are unable to carry out the update, use the fixed plesk_agent_manager as below:
  1. Back up the original file:
    # cp /usr/local/psa/admin/bin/plesk_agent_manager{,.orig}
  2. Replace the file with the fixed plesk_agent_manager
  3. Make sure that plesk_agent_manager has the correct permissions and ownership:
    # stat /usr/local/psa/admin/bin/plesk_agent_manager
    Access: (0755/-rwxr-xr-x) Uid: ( 500/ psaadm) Gid: ( 500/ psaadm)
    Change permissions if necessary:
    # chmod 755 /usr/local/psa/admin/bin/plesk_agent_manager
    # chown psaadm:psaadm /usr/local/psa/admin/bin/plesk_agent_manager
