- Plesk 12.5 for Linux
Repairing MySQL using Plesk repair utility fails:
# plesk repair mysql -v
The user user is absent from the database server ............... [ERROR]
Recreate the user user with default permissions and default hosts? [Y/n]
Recreating the user user ..................................... [FAILED]
- Operation CREATE USER failed for 'user'@'%'
Error messages: 1; Warnings: 0; Errors resolved: 0
exit status 1 -
It is not possible to create a user manually:
# plesk db
mysql> CREATE USER 'user'@'%' IDENTIFIED BY 'password';
mysql> ERROR 1396 (HY000): Operation CREATE USER failed for 'user'@'%' - The migration might fail with the following error:
PLESK_ERROR: stderr: Unable to add database user: Operation CREATE USER failed for 'user'@'%'
Such user already exists.
Also, the error can be caused by the MySQL bug: https://bugs.mysql.com/bug.php?id=28331
Connect to the server using SSH.
Create a dump of the database
mysql
:# MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysqldump -uadmin mysql > /root/mysql_db_backup_
date +%F.%s
.sql -
Access MySQL server and switch to the database
mysql
:# plesk db
mysql> use mysql -
Remove the user mentioned in the error message from the table
mysql.user
:MYSQL_LIN: mysql> DROP FROM user WHERE User='user';
Remove the permissions for this user from the table
mysql.db
:MYSQL_LIN: mysql> SELECT * FROM db WHERE User='user';
If steps above did not help, delete this user as a workaround for the MySQL bug:
MYSQL_LIN: mysql> DROP USER user;
