Unable to publish website: Read timed out after 10 seconds
Created:
2016-11-16 12:55:05 UTC
Modified:
2017-04-24 12:07:41 UTC
Have more questions?
Submit a request
  • Web Presence Builder 12.5 for Windows
Unable to publish the website due to the following error:
        Unable to connect to web presence builder server
In "%plesk_dir%\\admin\\logs\\plesklog_sitebuilder.log" the following error appears:
    2016/06/18 10:53:01:982 11512 924 2016-06-18T10:53:01+05:30 [EMERG] /sitebuilder/JsonApi/   Zend_Http_Client_Adapter_Exception: Read timed out after 10 seconds
file: C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\externals\\Zend\\Http\\Client\\Adapter\\Socket.php
line: 511
code: 1000
After editing Web Presence Builder configuration file located in %plesk_dir%\sb\config and adding:
[internal]
send_errors = false
The following can be found in %plesk_dir%\\admin\\logs\\plesklog_sitebuilder.log :
168028 57896 2016-09-13T16:25:43+01:00  [EMERG] /sitebuilder/JsonApi/   Symfony\\Component\\Debug\\Exception\\ContextErrorException: Warning: scandir(C:/Program Files (x86)/Parallels/Plesk/sb/htdocs/sites/36/36bcdd63e46ad2a019a096f015f0e018/attachments/builtin/Header/,C:/Program Files (x86)/Parallels/Plesk/sb/htdocs/sites/36/36bcdd63e46ad2a019a096f015f0e018/attachments/builtin/Header/): The system cannot find the file specified. (code: 2)
file: C:\\Program Files (x86)\\Parallels\\Plesk\\sb\\include\\SB\\Site.php
line: 570
code: 0
in C:\\Program Files (x86)\\Parallels\\Plesk\\sb\\include\\SB\\Site.php on line 570
#12 at Zend_Controller_Action->dispatch("defaultAction")in C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\externals\\Zend\\Controller\\Dispatcher\\Standard.php on line 295
#13 at Zend_Controller_Dispatcher_Standard->dispatch(object(SB_Controller_Request_Http), object(Zend_Controller_Response_Http))in C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\externals\\Zend\\Controller\\Front.php on line 954
#14 at Zend_Controller_Front->dispatch()in C:\\Program Files (x86)\\Parallels\\Plesk\\sb\\include\\SB\\Application\\Web.php on line 262
#15 at SB_Application_Web::run()in C:\\Program Files (x86)\\Parallels\\Plesk\\sb\\htdocs\\index.php on line 3
Inconsistency in Web Presence Builder website directory.
  • Determine missing directory from the error under scandir() :
  • Manually create this directory, in this example: C:/Program Files (x86)/Parallels/Plesk/sb/htdocs/sites/36/36bcdd63e46ad2a019a096f015f0e018/attachments/builtin/Header
