A website hosted in Plesk fails to load when ModSecurity is enabled: Access denied with code 403
4 comments
    Tony
    It's worth noting the free Atomic list wont get this fix/update until next month, right?
    I'm having trouble using Plesk 12.5 UI to Switch off the Rule by ID.  Is the correct ID format  "[id "340465"]"?
    Tony
    After updating to the $200/yr paid Atomic list this issue is resolved.  I think otherwise i would've had to wait 30 days for the free delayed updates to be deployed to me.
    Lev Iurev
    @Tony issue should be fixed by running abovementioned command
    Omkar More
    I am still getting the problem, it all started after i installed modsecurity in extensions, now my website resources are getting consumend and getting above error as well as xmlrpc thing. What would be appropriate solution for this as I am thinking would there be any conflict between wordpress security plugin and plesk modsecurity
