How to optimize Plesk for Linux for against a SYN-Flood attack
2 comments
    Sid (Edited )
    Under vz7 this does not work in a container.
    # sysctl -p
    sysctl: cannot stat /proc/sys/net/ipv4/tcp_syncookies: No such file or directory
    sysctl: cannot stat /proc/sys/net/ipv4/tcp_fin_timeout: No such file or directory
    sysctl: cannot stat /proc/sys/net/ipv4/tcp_window_scaling: No such file or directory
    sysctl: cannot stat /proc/sys/net/ipv4/tcp_sack: No such file or directory
    Nikita Nikushkin
    Hi @Sid,
    I suppose, your kernel has no enabled "tcp_syncookies", "tcp_fin_timeout", "tcp_window_scaling" and "tcp_sack" support
    Thus, the mentioned files are not present in the "/proc/sys/net/ipv4" folder and thus you are unable to manage them
    Please note that the provided solution is valid if the mentioned modules are already loaded and available for managing
