Plesk migration has finished with warning: the extract path is too long
Created:
2016-11-16 12:52:53 UTC
Modified:
2017-06-09 07:51:57 UTC
Have more questions?
Submit a request
  • Plesk for Windows
Plesk migration on windows systems has finished with the following warning:
Warning:    hosting "DOMAIN.TLD"Can not deploy content of domain DOMAIN.TLDWarning:    Repository error: Archive could not be extracted because the extract path is too long
In Windows API (with some exceptions), the maximum length for a path is MAX_PATH defined as 260 characters. A local path is structured in the following order: drive letter, colon, backslash, name components separated by backslashes, and a terminating null character. For example, the maximum path on drive D is " D:\\some 256-character path string<NUL> " where " <NUL> " represents the invisible terminating null character for the current system codepage. (The characters < > are used here for visual clarity and cannot be part of a valid path string.)
On the source:
  1. Use " tree /F > tree.txt " utility to view tree of folders and locate largest path/filename.
  2. Use third-party archiver (for example 7-Zip) to aggregate the folder with problematic path/filename to archive.
  3. Migrate the domain again.
On the destination:
  1. Run the archiver as Administrator and set the temporary working folder for archiver as "Current" (options\folders). Restore problematic folder from archive.
BTW : As an alternative solution, use " subst " utility to associate a path " C:\\inetpub\\vhosts\\<DOMAIN_NAME>\\httpdocs\\ ' to a drive letter.
