How to sync hard disk quota
Created:
2016-11-16 12:52:01 UTC
Modified:
2017-07-19 11:22:59 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk 11.5 for Linux
  • Plesk 12.0 for Linux
The hard disk quota in the Plesk Panel does not match the one set on the server:
File system:
#  quota -u examplecomsysuser
Disk quotas for user examplecomsysuser (uid 10000):
Filesystem blocks quota limit grace files quota limit grace
/dev/ploop44487p1
39032 0 1953125 1661 0 0
Plesk Panel: Subscriptions > example.com > Websites & Domains > Web Hosting Access or
# /usr/local/psa/bin/subscription -i example.com |grep 'quota'        Hard disk quota:                        500 MB
How do I update hard quota, set correct value?
Please use the subscription utility
# /usr/local/psa/bin/subscription -u example.com -hard_quota 200M
To set the hard quota value to the one specified in subscription properties please use the following command:
# subscription_name='example.com';quota_val=$(mysql -uadmin -p$(cat /etc/psa/.psa.shadow) psa -sNe "select quota from sys_users join hosting on hosting.sys_user_id=sys_users.id join domains on  hosting.dom_id=domains.id where domains.name ='$subscription_name'"); /usr/local/psa/bin/subscription -u $subscription_name -hard_quota $quota_val"B"
