Multiple issues after upgrade Plesk to 12.5 on CentOS/RHEL/CloudLinux 5 and 6
Created:
2016-11-16 12:52:00 UTC
Modified:
2017-08-08 13:45:24 UTC
1
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
On a Plesk 12.5 server with nginx enabled, one or more of the the following occurs:
  • Fail2ban bans IP addresses belonging to the server.
  • The web statistics data shows that all visits to websites are from local IP addresses.
  • The Apache access logs contain the Plesk server IP instead of the actual IP address of the visitor.
  • The $_SERVER['REMOTE_ADDR']; variable in your PHP code returns the IP address of the Plesk server instead of the actual IP address of the visitor.
During the upgrade to Plesk 12.5 the mod_rpaf Apache module was disabled.
This issue was fixed in Plesk 12.5.30 MU #7. If you upgraded to Plesk 12.5 before the microupdate was released, you can enable the module manually. Run the following command:
# plesk sbin httpd_modules_ctl --enable rpaf
to enable the module and resolve the issue.
