How to use Webex on Linux?
Created:
2016-11-16 12:50:56 UTC
Modified:
2017-04-24 11:21:16 UTC
1
Have more questions?
Submit a request
  • Plesk
What are the system requirements for WebEx on Linux?
WebEx will support any Linux distribution as long as it meets the following minimum requirements:
  • Kernel: 2.6 or later
  • X Lib: X11R6 or later compatible
  • C++ Lib: libstdc++ 6
  • Desktop Environment: XFce 4.0 or later, KDE, Ximian, Gnome
  • GDK/GTK+ version: 2.0 or later
  • Glib: 2.0 or later
  • Sun Java 1.6 or later
Full list of supported OS can be found on Cisco Webex site .
