How to change the default location of mailboxes in Plesk for Linux
22 comments
    Alisa Kasyanova
    @German A
    Thank you for the question. When Courier is used, there is no need to change anything on step 6. On step 7, restart all Courier services (courier-authdaemon, courier-imapd, courier-imaps, courier-pop3d and courier-pop3s)
    Dinara Aspembitova
    Hello @German A,
    >chcon: can't apply partial context to unlabeled file
    The 9 step is applied if Selinux is used, otherwise this step can be skipped.
    You can check Selinux status using the command below:
    getenforce
    As for the following message:
    >plesk repair mail
    >PHP Notice: Undefined index: mail in /usr/sbin/plesk on line 57
    >Usage: plesk [command]
    "plesk repair mail" command was introduced in Plesk 12.5, as I can see your Plesk version is 12.0.
    Note that Plesk version 12.X has reached End of Life starting from 1.01.2019.
    End-of-Life means that the product will cease to receive further development and technical support requests will no longer be accepted https://www.plesk.com/support/plesk-lifecycle/
    It is strongly recommended to upgrade Plesk to the supported version.
    >Finally I think there is another problem in step 10, since you never ask or guide to "cp" or migrate the "popuser" directory but you request to change it in "/etc/passwd", please clarify if you can.
    popuser is a specific user, which own all mailboxes in Plesk., since the mail home directory was changed, it is required to make the corresponding changes in "/etc/passwd".
    >There is an unedited line in "/etc/psa/psa.conf" that has this information:
    ># Qmail directory
    >QMAIL_ROOT_D /var/qmail
    >This shouldn't be updated as well?, BTW I did and still not working.
    There is no need to edit this line in "/etc/psa/psa.conf", only PLESK_MAILNAMES_D should be edited.
    German A
    Thanks for your complete and kind replies.
    As Plesk version 12.X has reached End of Life I understand that I can't get a support for that problem, BUT then I would just like to know if this missing step will affect the migration, since I need to finish this task.
    Thanks again and have a nice week.
    German A (Edited )
    Thanks for your previous answer, now there is an error on step 8 when executing "plesk repair mail"
    [root@ /]# plesk repair mail
    Commands:
    help - Show help and exit
    version - Show product version information
    db - Database related commands. Open MySQL console by default.
    bin - Run the specified Plesk command-line utility (e.g., domain, client)
    sbin - Run the specified Plesk internal utility
    php - Run a PHP script using the proper PHP interpreter
    conf - Open the specified Plesk configuration file in the editor
    log - Display the specified Plesk log file
    installer - Parallels Installer shortcuts and command completion.
    I hope this doesn't interrupt my service since is an enterprise solution for many clients. Thanks in advance for you kind help.
    ************UPDATE************
    # Qmail directory
    Should I use any of this utils instead?
    [root@ /]# /usr/local/psa/admin/bin/mailmng
    mailmng mailmng-core mailmng-imap mailmng-outgoing mailmng-service
    mailmng-black-white mailmng-domain mailmng-mailname mailmng-server mailmng-transport
    ***********LAST UPDATE************
    I sucessfully runned this command "/usr/local/psa/bootstrapper/pp12.0.18-bootstrapper/bootstrapper.sh repair" but I don't know if this is the substitute of "plesk repair mail".
    So I'll wait untill your reply. Thanks and sorry about this trouble.
    German A
    Hello every1, thanks for this extremly usefull and clear guide. My disk is full so I need to move all my mails to the brand new partition, permanently mounted on "/mnt/sdb/" using "ext4" as the primary one "/sda/sda1".
    I found a difference with in my installation on step 2, I got this:
    $features['SMTP_Server'] = "Postfix";
    $features['IMAP_POP3_Server'] = "Courier-IMAP";
    $features['SMTP_Server_package'] = "postfix";
    $features['IMAP_POP3_Server_package'] = "courier-imap";
    So, what do I have to change in place of your "dovecot" configurations in steps 6 and 7.
    Im using Plesk v12.0.18_build1200140606.15 os_CentOS 6 on CentOS 6.9 (Final).
    Thanks,
    German
    Lenor
    thank you,
    if i have a firewall who checks UDP/ TCP Ports IN/ OUT which Ports do i have to allow in Ordner to have everything working normal?
    Emilio Ortiz
    Very weird error the creating email after migrate folder if path contains uppercase.
    "unable to change to mbox folder /media/2tb/mailnames/"
    "Fatal error: plesk::mail::FSError(unable to remove quota: Success: "/media/2TB/mailnames/"
    I've solved it creating a symlink from "2tb" to "2TB". I think could be a bug.
    I've checked twice misspelling on both files.
    PS: Also step 9 is not needed en Ubuntu.
    German A
    Thanks!
    b_p
    What is missing in this instruction set is an update of the apparmor configuration?!
    Stuart Mayne (Edited )
    Following the above guide, I was left unable to log into the mailboxes (even using webmail). So I reverted back to the original dovecot and postfix configurations, and re-run the mchk utility - and access was returned. Have I missed something?
    Furthermore - one of your collegues recently posted a warning that the "mchk" command is not advised, and that instead admins should instead, be using "plesk repair mail" ...which is the better advice?
    https://talk.plesk.com/threads/all-mail-passwords-are-gone-after-mchk.346354/#post-840746
    Filipe
    After update the path in "/etc/dovecot/dovecot.conf" changed back to default causing Mailbox unavailability. It would be great if updates wouldn't interfere with this configuration. This could be a feature inside Plesk instead of manipulating configuration files that can be overwritten. Or even alert us before updates that can potentially break this configuration.
    Any improvement to this is welcomed.
    Thanks
    Nikolay Zhmuk
    @Stuart Mayne hi, I checked the solution described in the article step by step and it works as expected. Have you run mchk utility as it is suggested on the step 8?
    Regarding question about 'plesk repair mail' utility, such tool extends the functionality of mchk. It runs mchk tool along with the other repair actions, that is why it was recommended to use. Note that I have updated the article and replaced mchk with plesk repair mail.
    Ivan Postnikov
    @Daniele Vasalli
    Hello!
    The backup manager will use the new mailboxes path. It was checked on a test server.
    Emilio Ortiz
    I'm not migrating platform. I'm only changing the path of the mail folder to a bigger one.
    • Product version: Plesk Onyx 17.5.3 Update #39
    • Update date: 2018/01/31 14:37
    • Build date: 2017/03/17 16:00
    • OS version: Ubuntu 16.04
    • Revision: 55d1b49a272f44666e1920eca8b6e4da449a38cd
    • Architecture: 64-bit
    • Wrapper version: 1.2
    Plesk Migrator is not installed.
    Regards!
    Unknown User
    After moving the mailboxes path, does the backup consider the new path?
    Lenor (Edited )
    Hi, is there no way, to make this changes permanent?
    We lost this today, again.
    EDIT:
    Well i createt a File: /etc/dovecot/conf.d/custom.conf and this works perfectly.
    Just enter all things from dovecot.conf which you want to change, and done.
    Or do i miss somthing? This works great. And this would keep Changes on Update, right? So maybe you can adjust Article.
    German A
    Also, the next step 9, "chcon -R -t mail_spool_t /mnt/sdb/qmail/mailnames/" throw me thousands of errors like this:
    chcon: can't apply partial context to unlabeled file `new'
    chcon: can't apply partial context to unlabeled file `tmp'
    chcon: can't apply partial context to unlabeled file `cur'
    chcon: can't apply partial context to unlabeled file `.Spam'
    chcon: can't apply partial context to unlabeled file `Maildir'
    chcon: can't apply partial context to unlabeled file `@attachments'
    chcon: can't apply partial context to unlabeled file `.qmail'
    So I guess the previous command was necessary or there is also something else wrong. I hope you can help me and advise others like me. This is a brand new installation without any modification of the OVH VPS with the native Plesk installation.
    Thanks for reading and your kind help.
    Ivan Postnikov
    Hello @Lenor and @Filipe,
    Step 6 of the article was adjusted, now changes won't be reset after upgrades.
    Creating configuration in /etc/dovecot/conf.d/ allows to avoid this.
    Dinara Aspembitova
    Hello @b_p,
    Firstly, please note that Plesk Onyx supports AppArmor on Ubuntu 16.04 only since Ubuntu 14.04 reached End-Of-Life https://www.plesk.com/lifecycle-policy/
    As for your question, check where the old directory is specified in AppArmor.
    For example,
    # grep -r "mailnames" /etc/apparmor.d/*
    /etc/apparmor.d/local/usr.lib.dovecot.pop3:/var/qmail/mailnames/** rwk,
    /etc/apparmor.d/local/usr.lib.dovecot.dovecot-lda:/var/qmail/mailnames/** rwkl,
    /etc/apparmor.d/local/usr.lib.dovecot.imap:/var/qmail/mailnames/** rwk,
    Then, re-apply AppArmor policy and reset AppArmor cache:
    apparmor_parser -r -T -W <path-to-file>
    service apparmor recache
    Robert Asilbekov
    @Emilio Ortiz Could you please provide the following:
    1. Plesk migrator version
    2. Plesk version output
    3. Source platform you are migrating from
    4. Plesk technical report id: https://support.plesk.com/hc/en-us/articles/213374009
    Ivan Postnikov
    @Emilio Ortiz
    Hello!
    The issue was not reproduced in the test environment with the same OS and Plesk version.
    Consider contacting Plesk Technical Support
