Website or webmail shows 500 internal server error on Plesk: mod_fcgid: read data timeout
5 comments
    Christian
    Hello,
    When I paste the code in Additional nginx directives the code is red and I think this is wrong. My webmail is still slow from time to time. What can I do ?
    Can you help ?
    Regards
    Kris
    Configuration :
    Ubuntu 14.04.5 LTS
    Plesk Onyx Version 17.8.11 Update #18
    Anzhelika Khapaknysh
    Hi @Christian!
    Directives which are mentioned in the article, are designed for Apache web server, thus they can be added in following fields only:
    Christian
    In fact the problem was that I had too many connexions from users (my customers) using the webmail or at least postfix.
    I hire a guy that found that I should modify /etc/courier-imap/imapd
    He changed MAXDAEMONS to more that it was.
    MAXDAEMONS=128
    I hope that this can help anybody. Since that no more problems with error 500 or slow login in the webmail or anything slow using the webmail.
    share
    Christian,
    Glad to know the issue has been fixed!
    Just for your reference, the same solution is described in this article.
    Christian
    Thanks a lot
