Mail Outgoing Messages Statistics does not work
Created:
2016-11-16 12:50:33 UTC
Modified:
2017-04-24 11:23:23 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Windows
  • Mail Outgoing Messages Statistics does not work. No statistics are being generated at all.
  • MailEnable for x86 architecture is installed
  • Windows architecture is x64
Architecture mismatch between Plesk plugin for MailEnable and MailEnable server itself.
  1. Depending on MailEnable server architecture set proper path for 'Plugin DLL' parameter for registry key HKLM\SOFTWARE\Wow6432Node\Mail Enable\Connectors\SMTP in Windows registry Editor:
    C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\bin\\mesmtpplugin_x64.dll
    C:\\Program Files (x86)\\Parallels\\Plesk\\admin\\bin\\mesmtpplugin.dll
  2. Restart MailEnable SMTP Connector service.
  3. Run Daily Maintenance task to recalculate statistics:
    "%plesk_dir%"\\admin\\bin\\php.exe" -q ""%plesk_dir%"\\admin\\plib\\DailyMaintainance\task-script.php"
    StoreOutgoingMessagesStatistics
Note: Messages sent trough native MailEnable WebMail client will not be counted for outgoing messages statistics, because the native webmail client is not using SMTP protocol to deliver messages to MailEnable server.
