Manage Plesk branding using CLI or through database
Created:
2016-11-16 12:50:19 UTC
Modified:
2017-06-01 20:23:38 UTC
Have more questions?
Submit a request
Is there any CLI utility to manage Plesk branding?
I. Changing Plesk Branding through CLI:
1. Download the default theme:
# plesk bin branding_theme -p -name default -destination '/theme/defaullttheme.zip
2. Unpack it and modify meta.xml, replace ./images/logos/plesk/logo-web-host.png with a custom image. Please note that the theme directory structure should be kept.
3. Zip the theme back, install and activate it:
# zip -r customtheme.zip ./
# plesk bin branding_theme --install -vendor admin -source customtheme.zip
# plesk bin branding_theme --set -name customtheme
II. Changing Plesk Branding through database
Before modifying database, create PSA database backup according to instructions here:
  • 213904125 How to backup/restore a Plesk database dump?
To change Plesk Title, use the following query:
    # mysql -uadmin -p`cat /etc/psa/.psa.shadow` psa -e "update misc set val='MyTitle' where param='custom_title';"
To change Plesk Logo and URL attached to it, use the following instructions:
  1. Put the desired image into /usr/local/psa/admin/htdocs/images/logos/ directory.
  2. In Plesk database, check which ID the logos have:
    mysql> select val from misc where param='logo_id';
    If there are no any entries, any ID can be used for updating database. If there is an output like below, use ID that is specified (val=2):
    | val |
    | 2 |
  3. Update the database:
    mysql> replace Logos set `id`='2', `name`='image.png', `fake`='image.png', `url`='http//example.com';
    mysql> replace into misc (param, val) values("logo_id", "2")
Additional information
For information about working with custom themes, refer to Advanced Administrator Guides for Linux.
Plesk Branding CLI utility syntax is available in Command Line Utilities Guide .
