How to send Plesk Problem Report and get its ID
Created:
2016-11-16 12:50:09 UTC
Modified:
2017-05-20 09:55:48 UTC
1
Have more questions?
Submit a request
  • Plesk
How to send Plesk Problem Report and get its ID?
There two ways to create Problem Report in Plesk:
  • In Plesk go to Tools & Settings > Support > Generate a technical report before contacting support. (recommended)
    alttext
  • Using Command Line utility:
    # plesk bin report --collect
    # plesk bin report --send
To collect the information about the system, Plesk uses the tools known as collect-info or informer tools.
The result of the execution will be a .zip archive with the Plesk and system information. The archives could be found in:
  • On Linux:
    • /usr/local/psa/var/reports/collected/
  • On Windows:
    • %plesk_dir%\var\reports\collected
