- Plesk for Windows
How to enable debug mode for Plesk backup operations?
Nothing needs to be done. Logs are collected with debug mode enabled by default.
To increase verbosity for scheduled Plesk backups, enable the verbose_scheduled_backup_logs
parameter in the Plesk database using the following command:
To enable debug, run:
# plesk db "REPLACE INTO misc (param,val) VALUES ('verbose_scheduled_backup_logs', 'true')"
Warning: It is strongly recommended to disable verbosity once the troubleshooting is finished.
To turn debug off, run:
# plesk db "DELETE FROM misc WHERE param='verbose_scheduled_backup_logs'"
Add one or more verbose -v
options to the command.
For example, the following commands will back up the whole server with maximum verbosity in logs and output in a command-line interface:
on Linux:
# /usr/local/psa/bin/pleskbackup server -vvvvv
on Windows Server, multiple verbose options cannot be joined and have to be specified separately:
C:\> "%plesk_cli%\pleskbackup" --server -v -v -v -v -v
In addition to debug mode mentioned above, enable debug mode:
Open the
pmmcli-rc
file in a text editor (create a new one if it does not exist):-
on Linux:
CONFIG_TEXT: /usr/local/psa/admin/share/pmmcli/pmmcli-rc
on Windows Server:
CONFIG_TEXT: C:\Program Files (x86)\Plesk\admin\share\pmmcli\pmmcli-rc
Change the value of the
FORCE_DEBUG_LOG
parameter from 0 to 1:CONFIG_TEXT: FORCE_DEBUG_LOG 1
Save the changes and close the file.
Warning: It is strongly recommended to disable debug (remove the line above from the file) once the troubleshooting is finished.
Additional Information
Backup logs are located in the following directories:
on Linux:
/var/log/plesk/PMM/
in Plesk Obsidian -
/usr/local/psa/PMM/logs/
in Plesk Onyx
on Windows Server
%plesk_dir%PMM\logs\
Additional logs:
%plesk_dir%PMM\logs\pmmcli.log
,%plesk_dir%PMM\logs\pmmcli_daemon.log
