Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
How to switch IP address for domain in Plesk?
10 comments
    Bombicorp
    This feature seems to be gone in Plesk Onyx 17.5???   PLEASE put it BACK!!!
    Artyom Baranov
    @Bombicorp,
    Hello! The option exists on Plesk Onyx 17.5. Please check, maybe you have no additional IP addresses to select, or there are no free dedicated IP addresses.
    1
    aqila abdurakhman
    not available on my Plesk Onyx 17.8.11 Windows, anyone know how to enable it?
    Alexandr Tumanov
    Hello @aqila abdurakhman, are you Plesk administrator?
    Could you please explain in details what is missing?
    aqila abdurakhman
    Hello Alex, sorry i was miss understand between "Hosting Setting" and "Web Hosting Access" i thought it was the same menu, but i realise that it was different. now i can change the subscription IP.
    Ivan Postnikov
    Glad to hear that!
    Cem Sayar
    Can it be done for all domains with one command, i just got a new ip
    Lev Iurev
    @Cem Sayar      Check the section To change IP for multiple subscriptions in this article
    Grace Yang
    Hi, I can't change my IP address, it can only be viewed, and there is no editing option for it... How can I change it? Is there any other options to solve it?
    julian bonpland mignaquy
    Hi Grace Yang please make sure you added a new IP in Tools and Settings > IP addresses before changing it for the domain in Domains > example.com > Web Hosting Access.
