How to check Plesk server for possible issues before upgrade?
10 comments
    Sascha Schlüter
    This tool is a great option and exactly what i searched for, but i can´t run the pre-upgrade checker as i don´t know the 'plesk-db-admin-password'.
    Is there any syntax to use the encrypted password from /etc/psa/.psa.shadow in this command?
    Ivan Postnikov
    Hello @Sascha,
    As I can see, you are using Plesk for Linux.
    For Linux, <plesk-db-admin-password> is the same as admin password to access Plesk UI.
    Sascha Schlüter
    Thank you, Ivan, for your quick help.
    This was my first guess too, but unfortunately this does not work in my case. Using the same password, which does the job for user admin on servername.ext:8443  results in a message reading
    [FATAL_ERROR] [MYSQL ERROR] Given <password> is incorrect. Access denied for user 'admin'@'localhost' (using password: YES)
    Sascha Schlüter
    Ah - i just found a workaround while reading other articles: the encrypted password from /etc/psa/.psa.shadow works when set in "" and with all (not only the first!) $-characters are escaped with a "\"(backslash)-chraracter!
    Thank you for providing help!
    Alexandr Redikultsev
    Hi, @Sascha.
    Yes, you are right.
    Password for MySQL on plesk for Linux is hashed into /etc/psa/.psa.shadow, so the following command will get you into MySQL without the password:
    # MYSQL_PWD=`cat /etc/psa/.psa.shadow` mysql -uadmin
    Claudio
    Sascha, use backticks around the cat command:
    /opt/plesk/php/5.6/bin/php -d safe_mode=Off panel_preupgrade_checker.php `cat /etc/psa/.psa.shadow`
    Documentation should be updated.
    Julian Bonpland Mignaquy
    @Claudio the documentation has been updated. Thanks for bringing that up to our attention!
    Amarnath Mahato
    The below link doesn't contains Prechecker details for Obsidian version -- http://autoinstall-win.plesk.com/
    Please update the url for obsidian Pre-Checker script.
    Ivan Postnikov
    Hello Amarnath Mahato
    The Development team is aware of this and has a task to make Obsidian browsable here: http://autoinstall-win.plesk.com/
    Also, it will be considered to simplify/automate this procedure in the future.
    Paul S
    plesk checkupgrade
    Errors found: 0; Warnings found: 0
    Product version: Plesk Obsidian 18.0.41.1
         OS version: VZLinux 7.9.0 x86_64
         Build date: 2022/02/07 23:00
           Revision: 8cecdf6536124408249dd8ea2063e3e6f632ba5b
    but when i tried to upgrade current version
    Exception: Failed to solve dependencies:
    plesk-core-utilities-18.0-2.centos.7+p18.0.43.0+t220406.1450.x86_64 requires python3-libs
    plesk-service-node-utilities-18.0-2.centos.7+p18.0.43.0+t220406.1450.x86_64 requires python3-libs
    ERROR: The Yum utility failed to install the required packages.
    Attention! Your software might be inoperable.
    Visit https://support.plesk.com/ to search for a solution.
    exit status 1
    and no kb for this
