How do I downgrade Plesk Client IP addresses in OBAS?
Created:
2016-11-16 12:47:58 UTC
Modified:
2017-05-11 09:40:22 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Linux
Can I change the number of IP addresses in the Plesk Client Hosting Plan to zero?
In the current Odin Business Automation Standard (OBAS) implementation, dedicated IP addresses assigned to the Plesk client are a non-downgradable resource and cannot be downgraded directly from the control panel.
The following error is shown when attempting to downgrade the resource through Control Panel > Account > Buy Resources :
Number of IP addresses cannot be lower than N ip(s)
This behavior is considered to be a software issue. The fix will be included in future OBAS updates released after 4.5. You can track the issue using the following ID:
PBAS-18775 - downgrade number of IPs assigned to Plesk Client
Stay connected with the all the latest Service Provider news from Parallels. To subscribe or manage your current subscription preferences, please use this form: http://www.parallels.com/about/subscribe .
Hotfix for OBAS 4.x
Since the issue requires complex manipulations in the database, it is recommended that you contact Odin Technical Support for assistance.
