Domain statistics are not calculated if the 'cronie' and 'cronie-anacron' packages are installed
Created:
2016-11-16 12:46:30 UTC
Modified:
2017-08-16 18:30:27 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk 11.x for Linux
  • Plesk 12.0 for Windows
  • Plesk 12.0 for Linux
Web statistics do not work - no statistics are shown for domains.
Information
By design, web statistics are calculated by the /etc/cron.daily/50plesk-webstat script on Apache service nodes on a daily basis. The script writes its results into the /usr/local/psa/var/log/web_statistic_executor.last.log file.
Check the file for possible errors. If it is not up to date, check which cron packages are installed on your server.
The issue may be caused by errors in the " cron " and " anacron " packages:
~# rpm -qa | grep cron
cronie-1.4.4-7.el6.i686
cronie-anacron-1.4.4-7.el6.i686
And the " cron " was configured for hourly jobs:
~# ll /etc/cron.d/
totale 8
-rw-r--r-- 1 root root 113 19 lug 2011 0hourly
-rw-r--r-- 1 root root 459 18 giu 2012 sa-update
And the " anacron " for daily, weekly and monthly:
~# cat /etc/anacrontab | grep cron
# /etc/anacrontab: configuration file for anacron
# See anacron(8) and anacrontab(5) for details.
1 5 cron.daily nice run-parts /etc/cron.daily
7 25 cron.weekly nice run-parts /etc/cron.weekly
@monthly 45 cron.monthly nice run-parts /etc/cron.monthly
But the " anacron " service does not exist in system:
~# service crond status
crond (pid 635) in running...
~# service anacron status
anacron: unknown service
Daily, weekly and monthly tasks should be run from the file /etc/cron.d/dailyjobs .
  1. Move the /etc/cron.hourly/0anacron file away:
    ~# mv /etc/cron.hourly/0anacron ./
  2. Create the file /etc/cron.d/dailyjobs with the following strings:
    SHELL=/bin/bash
    PATH=/sbin:/bin:/usr/sbin:/usr/bin
    MAILTO=root
    HOME=/
    02 4 * * * root [ ! -f /etc/cron.hourly/0anacron ] && run-parts /etc/cron.daily
    22 4 * * 0 root [ ! -f /etc/cron.hourly/0anacron ] && run-parts /etc/cron.weekly
    42 4 1 * * root [ ! -f /etc/cron.hourly/0anacron ] && run-parts /etc/cron.monthly
