- Plesk 12.0 for Linux
- Plesk 9.x for Windows
Migration from Parallels Plesk 9.5 shows following warning:
Unable to create a hosting plan: Wrong syntax for command's '-webstat' parameter. 'true' does not match the pattern '/^(none|webalizer|awstats|smarterstats|urchin)$/'.
The webstat parameter is set up incorrectly in Plesk system database. In turn, this is likely caused by previous failed Plesk upgrades.
mysql> select * from tmpldata where element = 'webstat';
| tmpl_id | element | value |
| 7 | webstat | true |
| 9 | webstat | smarterstats |
| 10 | webstat | none |
| 11 | webstat | webalizer |
| 12 | webstat | smarterstats |
| 15 | webstat | none |
| 21 | webstat | none |
| 22 | webstat | none |
8 rows in set (0.13 sec)
Open properties of domain template and set the proper value to webstat option and save changes.
