- Plesk 12.5 for Linux
- Plesk 11.x for Linux
- Plesk 12.0 for Linux
Plesk installation is failed with error in plesk installation log:
END OF INNODB MONITOR OUTPUT
Attempting to check APS db connection via ODBC, using /usr/bin/iusql (empty output is good)
ERROR while trying to store APS controller db connection parameters into product db < ======= (!)
Check the error reason(see log file: /tmp/plesk_11.0.9_installation.log), fix and try again
I tried the solution described in /213382169 but it did not help.
By some unknown reason Plesk was not able to add
aps_*
values into
psa.misc
table.
It is possible to add connection details manually:
# mysql -uadmin -p` cat /etc/psa/.psa.shadow ` psa
INSERT INTO `misc` VALUES ('aps_database','apsc'),('aps_host','localhost'),('aps_login','apsc'),('aps_password','my_secret_password'),('aps_port','3306'),('aps_secure_passwords','true');
UPDATE misc SET val = 'false' WHERE param = 'secure_passwords'
UPDATE misc SET val='my_secret_password' WHERE param = 'aps_password';
grant all privileges on apsc.* to 'apsc'@'localhost' identified by 'my_secret_password';
flush privileges;
