How to rebuild qmail queue if it is damaged or contains a lot of spam messages?
Created:
2016-11-16 12:45:05 UTC
Modified:
2017-08-16 17:28:50 UTC
Have more questions?
Submit a request
  • Plesk 11.x for Linux
These instructions are written for RPM-based systems (RedHat, Fedora, CentOS, etc.). Instructions for DEB-based systems (Debian, Ubuntu) can be found in KB article #213925725 .
Please perform the following steps to recreate Qmail's queue.
Attention!
All current messages will be removed from the queue and cannot be restored.
  1. Stop Qmail and xinetd.
    # /etc/init.d/qmail stop
    # /etc/init.d/xinetd stop
    1. Move the current queue to another location.
      mv /var/qmail/queue /var/qmail/queue_old
  2. Reinstall psa-qmail RPM to recreate qmail queue structure with the command:
    # rpm -Uvh --force psa-qmail
  3. (Optional) Reinstall drweb-qmail RPM if you use the Dr. Web anti-virus feature which comes with Plesk.
    # rpm -Uvh --force drweb-qmail
  4. Start Qmail and xinetd:
    # /etc/init.d/qmail start
    # /etc/init.d/xinetd start
Note: You should get both the psa-qmail and drweb-qmail RPMs from the same Plesk version distributive which is installed on the server. All necessary packages you may find here .
You can obtain the current psa-qmail RPM, drweb-qmail RPM, and Plesk build version by running the following commands on Linux systems:
# rpm -q psa-qmail
# rpm -q drweb-qmail
# rpm -q psa
