How to change virtual hosts location in Plesk for Linux?
9 comments
    web studio (Edited )
    hello i get error message 502 Bad Gateway and 503 on domains client after using this guide. Version Plesk Onyx v17.5.3_build1705170317.16 os_CentOS 7
    Artyom Baranov
    @web studio,
    I suppose that you have faced the bug from the "Warning" message (Plesk Onyx, enabled SELinux).
    Contact Plesk support to assist you in resolving the issue: https://www.plesk.com/contact-support
    Diego Alvarez
    Thank you!!! Muchas gracias, estaba buscando esta solución hace 1 mes, y con este script pude cambiar de carpeta el virtual host.
    Thank You!!!
    Jean Poulain
    Hi !
    Is this problem now corrected by updates ?
    Thanks
    Nikita Nikushkin (Edited )
    Hi @Jean Poulain,
    The bug "#PPPM-6521" is not fixed yet
    As a workaround, before changing the vhosts folder, set SELinux to permissive mode:
    How to enable/disable SELinux on a server?
    For correct websites working capacity, SELinux has to be in the permissive mode even after changing websites vhosts directory
    I also updated the article with this information
    Giorgio Monticelli
    When you write "As an alternative workaround, mount new partition as /var/www/vhosts." what is the procedure?
    I just have my domain in var/www/vhosts and if I mount the additional hard disk the data I think disappear.
    Ivan Postnikov
    Hello @Giorgio,
    Generally, the procedure is similar to steps described here (just mount new partition to /var/www/vhosts):
    https://www.tecmint.com/move-home-directory-to-new-partition-disk-in-linux/
    Let me warn you that this is an administrative task and misconfiguration during following the steps may lead the server to stop booting.
    As you already have content at /var/www/vhosts I would recommend to change the virtual hosts location, as proposed in this article.
    Karol Kwiecien
    I followed this procedure on 3 instances and at 1 I have the following:
    Error 1146 (42S02) at line 1: Table 'psa.ServiceInstanceProperties' doesn't exist and system hangs on Correct user scripts.
    Any idea what to do? I have a problem with 1 of the websites which gets now 503 error.
    SElinux was disabled (and still is)
    regards
    Karol
    Ekaterina Babenko
    Hello Karol,
    The 'psa.ServiceInstanceProperties' message can be safely ignored. This database existed in Plesk 12.x only. As script applicable for all Plesk versions the error appears.
    The website error is too generic and to be addressed properly it should be investigated in ticket:
    https://support.plesk.com/hc/en-us/articles/213608509-How-to-submit-a-request-to-Plesk-support-
