How to change virtual hosts location in Plesk for Linux?
5 comments
    web studio (Edited )
    hello i get error message 502 Bad Gateway and 503 on domains client after using this guide. Version Plesk Onyx v17.5.3_build1705170317.16 os_CentOS 7
    Artyom Baranov
    @web studio,
    I suppose that you have faced the bug from the "Warning" message (Plesk Onyx, enabled SELinux).
    Contact Plesk support to assist you in resolving the issue: https://www.plesk.com/contact-support
    Diego Alvarez
    Thank you!!! Muchas gracias, estaba buscando esta solución hace 1 mes, y con este script pude cambiar de carpeta el virtual host.
    Thank You!!!
    Jean Poulain
    Hi !
    Is this problem now corrected by updates ?
    Thanks
    Nikita Nikushkin (Edited )
    Hi @Jean Poulain,
    The bug "#PPPM-6521" is not fixed yet
    As a workaround, before changing the vhosts folder, set SELinux to permissive mode:
    How to enable/disable SELinux on a server?
    For correct websites working capacity, SELinux has to be in the permissive mode even after changing websites vhosts directory
    I also updated the article with this information
