How to enable core dumps for Apache and trace Apache segmentation fault on a Linux server
4 comments
    Tony
    is there a default directory/location plesk-php74-fpm/error.log core dumps get saved?  I see lines like this but i don't know how to get more information.
    `WARNING: [pool example.com] child 466554 exited on signal 11 (SIGSEGV - core dumped) after 1.221340 seconds from start`
    Tony (Edited )
    nevermind.  i can see now that this information DOES apply to my apache php-fpm server. i did have to find the correct php-fpm to pass
    root@servername:/var/coredumps# gdb /opt/plesk/php/7.4/sbin/php-fpm /var/coredumps/core-php-fpm-11-10109-1006-505241-1632347775
    Tony
    except
    apt-get install apache2-dbg
    E: Unable to locate package apache2-dbg
    Tony
    i then found i could enable/disable the core dump for the specific domain by customizing the php directives for that specific domain in plesk eg.
    [php-fpm-pool-settings]
    rlimit_core = unlimited
    (and then remove that to disable the core dumps!   six core dumps from my site were 1.8GB in disk size, so be careful!
