Plesk shows error 500.19, x86 application pools do not work
Created:
2016-11-16 12:44:07 UTC
Modified:
2017-04-24 12:13:36 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Windows
WSUS is installed in IIS. No 32bit application pools load, Plesk Panel shows the error:
    HTTP Error 500.19 – Internal Server Error
The requested page cannot be accessed because the related configuration data for the page is invalid. Module DynamicCompressionModule
Notification SendResponse
Handler StaticFile
Error Code 0x8007007e
Requested URL https://localhost:8443/
Physical Path <some Path>
Compression Scheme is enabled and the 32-bit web apps do not support compression.
Run the following command:
    %windir%\\system32\\inetsrv\\appcmd.exe set config -section:system.webServer/httpCompression /-[name='xpress']
