kb: technical
ext: migrator
ABT: Group B
- High CPU wait, I/O and Load Average, while the backup is generated in Plesk or outbound migration, is performed.
- Sites may show 504 Gateway Timeout error.
/usr/bin/pigz
and/or /bin/tar
consumes high CPU resource during the backup process as it is involved in the backup compress process.
There are three possible solutions to reduce the server load during backup process, for that the following options can be enabled under Tools & Settings > Backup Manager > Settings:
- Run scheduled backup processes with low priority
- Run all backup processes with low priority
Do not compress backup files (this way the backup size will be larger, but load average will be less as
pigz
process that is involved in the backup compress process will be skipped).
These options launch pigz and tar with nice.
Note: these options increase the backup time. Other server tasks will not be affected. If there is a highly-loaded domain on a server that takes a lot of server resources, re-schedule the time to start a backup to the night when the number of visitors to the site is less.
2 comments
@... on my server, backups worked well until ~5 months ago. Since then, the weekly full backup creates a massively high load even though the nice value for backups is set to 19 and the ionice value to 7, and we already disabled backup compression. It feels that there needs to be an additional problem.
Hi b_p,
You might be experiencing the bug described in this KB. However, if you see this is not the case, I suggest to open a support ticket with us as further investigation on the server might be necessary.
