Domain is not secured: RC4 cipher algorithm is enabled
Created:
2016-11-16 12:43:05 UTC
Modified:
2017-06-29 04:34:37 UTC
1
Have more questions?
Submit a request
  • Plesk 12.0 for Linux
SSL test shows error:
Disable the RC4 cipher suite and update the web server to support the Advanced Encryption Standard (AES) cipher algorithm. Contact your web server vendor for assistance.
SSL test may be done with any public SSL checker, for example, https://cryptoreport.geotrust.com/checker/views/certCheck.jsp or https://www.ssllabs.com/index.html
PCI Compliance is enabled on a server.
RC4 ciphers are enabled
Edit /etc/httpd/conf/plesk.conf.d/server.conf file by adding the following line to exclude RC4 ciphers:
SSLCipherSuite ECDH+AESGCM:ECDH+AES256:ECDH+AES128:ECDH+3DES:RSA+AES:RSA+3DES:RC4+SHA!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!ADH:!AECDH:!MD5:!DSS:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA
