Too Many Redirects
Created:
2016-11-16 12:42:09 UTC
Modified:
2017-08-16 17:16:13 UTC
Have more questions?
Submit a request
Too Many Redirects
  • Plesk 11.x for Windows
  • Plesk 11.x for Linux
  • Log in to Plesk under non-admin account is impossible for domain domain.tld. Unable to log in to domain control panel, Plesk redirects in looping.
    This Webpage has a Redirect Loop
  • The subscription is temporarily suspended until the backup or restore process is complete.
  • Database inconsistency
  • If this subscription is under maintenance (i.e. backup/restore procedure) then wait until procedure is completed.
  • It it is not under maintenance perform the following:
  • Check sys_users' id of the name you are trying to log in with.
        mysql> select * from sys_users where login="%username%"\\G;
    *************************** 1. row ***************************
    serviceNodeId: 1
    login: %username%
    account_id: 5596
    home: C:/Inetpub/vhosts/domain.tld
    shell:
    quota: 0
    1 row in set (0.00 sec)
  • Check the status of the domains this user belongs to.
        mysql> select id,name,cl_id,vendor_id,webspace_id,parentDomainId, status from domains where id in (select dom_id from hosting where sys_user_id=10) and status!=0;
    | id | name | cl_id | vendor_id | webspace_id | parentDomainId | status |
    | 6890 | domain.tld | 970 | 1 | 3272 | 0 | 4 |
    1 row in set (0.23 sec)
  • Change the status of the domains to zero (enabled) to resolve the issue:
        mysql> update domains set status=0 where id in (select dom_id from hosting where sys_user_id=10);
NOTE: Domains can have only the following statuses:
> 0 -- enabled
> 1 -- none
> 2 -- parent object has been suspended
> 8 -- none
> 16 -- suspended by admin
> 32 -- suspended by reseller-owner
> 64 -- suspended by client-owner
> 128 -- none
> 256 -- expired
