- Plesk 11.x for Windows
- Plesk 12.0 for Windows
- Plesk 12.5 for Windows
- Plesk Onyx for Windows
- Plesk for Windows
MyLittleAdmin does not show databases list. The following pop-up notification appears:
CONFIG_TEXT: URL that was requested does not exist.
The page isn't redirecting properly.OR
CONFIG_TEXT: Timeout expired.
The timeout period elapsed prior to completion of the operation or the server is not responding. -
An attempt to get the User Databases menu stuck on this step:
CONFIG_TEXT: Retrieving data...
If trying to open the User Databases menu in a new browser tab, the following error may appear:
CONFIG_TEXT: Server error
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
The bug on MyLittleTools side that fails to handle the connection to the database when there are a lot of databases exist.
The following steps need to be done to get more detailed error:
Connect to the server via RDP.
Enable debug mode in the
%plesk_dir%MyLittleAdmin\config.xml
file:CONFIG_TEXT: <debug value="true"/>
Change the
httpRuntime maxRequestLength
directive with the following one in the%plesk_dir%MyLittleAdmin\web.config
file:CONFIG_TEXT: <httpRuntime maxRequestLength="204800" maxQueryStringLength="2097151" />
Comment the
httpErrors
block in the%plesk_dir%MyLittleAdmin\web.config
file:CONFIG_TEXT: <!--
<httpErrors errorMode="DetailedLocalOnly" defaultPath="./error/404.html" defaultResponseMode="ExecuteURL">
<remove statusCode="404" subStatusCode="-1" />
<error statusCode="404" prefixLanguageFilePath="" path="./error/404.html" responseMode="ExecuteURL" />
</httpErrors>
Right-click the User Databases menu in myLittleAdmin and press the Open in New Tab button to get the detailed error output:
The output of the error may be listed on the page in plain text (the output may be formatted differently, so use URL Decoder to get human-readable text):
CONFIG_TEXT: HTTP Error 404.15 - Not Found
The request filtering module is configured to deny a request where the query string is too long.
Detailed Error Information:
Module RequestFilteringModule
Notification BeginRequest
Handler PageHandlerFactory-Integrated-4.0
Error Code 0x00000000
Source: .Net SqlClient Data Provider
Message: Timeout expired. The timeout period elapsed prior to completion of the operation or the server is not responding.
Stack trace: at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj)OR
CONFIG_TEXT: Offending URL: .Net SqlClient Data Provider<br /><br /><strong>Message:</strong> Execution Timeout Expired. The timeout period elapsed prior to completion of the operation or the server is not responding.<br /><br /><strong>Stack trace:</strong> at System.Data.SqlClient.SqlConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
If there is a simply 404 error:
CONFIG_TEXT: 404 - File or directory not found.
then copy the URL of that page and decode it using any URL decoder. It will display similar content regarding .Net SqlClient Data Provider.
Contact MyLittleAdmin support for assistance:
