Presence Builder Templates fail to load
Created:
2016-11-16 12:41:22 UTC
Modified:
2017-05-11 09:35:01 UTC
Have more questions?
Submit a request
  • Plesk 11.0 for Linux
After installation, configuration and setup of Web Presence Builder, customers cannot load Design Templates. The web interface returns the error " Unable to connect to Parallels Web Presence Builder Server. Please contact your administrator ".
An error in /var/www/vhosts/1/<webspace_id>/log/ssl_error_log :
PHP Fatal error:  Allowed memory size of 25165824 bytes exhausted (tried to allocate 64 bytes) in
/var/www/vhosts/1/100001/webspace/siteapps/ParallelsPresenceBuilderforPA-1/htdocs/include/SB/ORM/Template.php on line 89
Web Presence Builder needs more memory to load the templates than it is currently allowed to use by the Apache configuration.
  1. Check that the value for memory_limit of the PHP Resource Limits in the Apache Configuration are properly set to 192M as described in the deployment guide.
  2. Check that the Apache Configuration is Applied state.
