Daily maintenance script takes up to 10 hours to complete. Webstatistics script takes too much time to process one domain
Created:
2016-11-16 12:40:58 UTC
Modified:
2017-08-08 13:29:32 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
  • Plesk 12.0 for Linux
Daily maintenance script /etc/cron.daily/50plesk-daily takes up to 10 hours to complete due to statistics utility:
zcat /var/log/cron.*.gz | grep 50plesk-daily
Jul 5 03:15:01 spl60 run-parts(/etc/cron.daily)[17122]: starting 50plesk-daily
Jul 5 11:35:56 spl60 run-parts(/etc/cron.daily)[3864]: finished 50plesk-daily
Jul 4 03:47:00 spl60 run-parts(/etc/cron.daily)[5332]: starting 50plesk-daily
Jul 4 12:40:07 spl60 run-parts(/etc/cron.daily)[1207]: finished 50plesk-daily
Manual recalculation for one domain can take up to 2 hours even if log files has small size:
# /usr/local/psa/admin/sbin/statistics --calculate-one --domain-name=example.com
This is an internal issue with ID #PPPM-3083 , which has been fixed in Plesk 12.0 microupdate #71 .
Apply the latest Plesk microupdates .
