WordPress installation on a subdomain: files and directories permissions issue
Created:
2016-11-16 12:40:17 UTC
Modified:
2017-06-10 12:14:35 UTC
Have more questions?
Submit a request
  • Plesk 12.5 for Linux
WordPress Security Check shows an error:
alttext
Clicking Secure button does not fix the issue.
"Permissions for files and directories" checker function changes permissions for non-WordPress files and directories.This is Plesk internal issue with id #PPP-17596 , which is planned to be fixed in future Plesk updates.
Workaround
Manually change the permissions for all subdirectories of DocumentRoot directory of the domain\ subdomain. In the example below the proper permissions are set for cgi-bin subdirectory:
# chmod 755 ./example.com/subdomain.example.com/cgi-bin/
