ASP.NET Settings menu is not accessible for Plesk customers/resellers after update to 18.0.52: 404 Page Not Found
4 comments
    anton.mozolkov (Edited )
    Hi! I have updated Plesk to version 18.0.52 #3 but the problem is with ASP.NET is still in place (not one server). What should I do?
    anton.mozolkov
    I just performed an update from version 18.0.51 where the choice is ASP.NET worked until version 18.0.52 #3. Now the choice of version ASP.NET it doesn't work.
    Permanently deleted user
    Hello Anton,
    The article above describes another issue that has been fixed.
    The inability to change the ASP.NET version in the ASP.NET Settings menu is caused by another bug with ID PPPM-13996 which is yet to be fixed. As a workaround, switch the version in the Domains > example.com > Hosting & DNS > Hosting menu instead.
    anton.mozolkov
    Thank you very much for the answer, Anastasia. I thought there might be a problem with our installations. Waiting for updates :)
