Is it possible to configure default settings for Websites Monitor under 360 monitoring product?
1 comment
    Damien Ransome
    This is a CRAZY way to set the default settings for all new websites!
    It means if I add monitoring for a special website which requires esoteric settings, all of my other sites (added after) will also be monitored with those same settings (accidentally).
    You should make an explicit setting to define the defaults...
