Plesk 360
Platform 360
360 monitoring
Is it possible to configure default settings for Websites Monitor under the 360 monitoring product? Such as default Monitoring location, sensitivity, and frequency of checks.
360 Monitoring copy settings such as location and others from the last added website:
- Create a website under 360 Monitoring and define the settings you want to have as default such as location, sensitivity and etc.
- All new websites will have these settings defined as defaults.
1 comment
This is a CRAZY way to set the default settings for all new websites!
It means if I add monitoring for a special website which requires esoteric settings, all of my other sites (added after) will also be monitored with those same settings (accidentally).
You should make an explicit setting to define the defaults...
