- Plesk for Windows
Repairing a domain in Plesk using CMD command
plesk repair web
shows error:C:\> plesk repair web
Missing ASP.net compilation temporary directory for domain:
example.com .................................................... [ERROR] -
The temporary directory in Plesk > Domains > example.com > ASP.NET settings shows:
CONFIG_TEXT: The path must be relative
This is a Plesk bug #PPP-52079 (Incorrect path is shown for ASP.NET temporary directory if <system.web> directive was removed from web.config
) that will be fixed in future product updates.
Until the bug is fixed the following workaround is available:
Connect to the server via RDP.
Open the command prompt as administrator and run
plesk repair web
command for each affected domain:C:\> plesk repair web example.com
