- Plesk for Windows
How to check a Plesk server for possible issues before the upgrade?
It can be done using the pre-upgrade checker script.
Follow the instructions below to use it.
Use the pre-upgrade checker:
To list available upgrades:
# plesk listupgrade
To run the pre-upgrade checker for checking the upgrade to the latest available version:
# plesk checkupgrade
To run the pre-upgrade checker for checking the upgrade to specific version:
# plesk checkupgrade 18.0.33
Download the archive with the pre-upgrade checker and unpack it:
on Linux:
# wget https://support.plesk.com/hc/en-us/article_attachments/360019939540/preupgrade_checker_linux.tar.gz
# tar -xzvf preupgrade_checker_linux.tar.gz -
on Windows: use the URL https://support.plesk.com/hc/en-us/article_attachments/360019939400/preupgrade_checker_windows.zip and unpack the archive using a preferred tool.
Note: On 32-bit operating systems, use the binary
preupgrade.386
instead ofpreupgrade.x64
on Linux:
# ./preupgrade.x64 list
# ./preupgrade.x64
# ./preupgrade.x64 18.0.33
on Windows:
preupgrade_x32.exe
instead ofpreupgrade_x64.exe
.\preupgrade_x64.exe list
.\preupgrade_x64.exe 18.0.33
