- These warnings can be seen in
/var/log/maillog
or/var/log/messages
:CONFIG_TEXT: dovecot: config: Warning: service auth { client_limit=1000 } is lower than required under max. load (1396)
dovecot: config: Warning: service anvil { client_limit=1000 } is lower than required under max. load (1399) -
Roundcube shows 500 Internal Server Error with the following errors in
/var/log/httpd/error_log
file:CONFIG_TEXT: [fcgid:warn] [pid 12406:tid 140260554016512] [client 203.0.113.2:42198] mod_fcgid: read data timeout in 45 seconds, referer: http://webmail.example.com/
[core:error] [pid 12406:tid 140260554016512] [client 203.0.113.2:42198] End of script output before headers: index.php, referer: http://webmail.example.com/ -
Mail clients might fail to connect.
The default_client_limit
parameter is too low for Dovecot.
- Connect to the server via SSH
Note: If direct SSH access to the server is not possible, contact server administrator for further assistance.
- Create
/etc/dovecot/conf.d/10-master.conf
file using text editor to changeclient_limit
for all dovecot services:CONFIG_TEXT: default_client_limit = 1500
- Restart dovecot to apply the changes:
# service dovecot restart
Note: If after raising the default_client_limit
the same error message still showing up, increase more the limit.
1 comment
The file 10-master.conf not fund
