- Plesk Onyx for Linux
- Plesk Onyx for Windows
Connection to Plesk UI is displayed as insecure despite having a valid Let's Encrypt certificate installed.
The similar warning appears in the browser when opening https://plesk.example.com:8443/:CONFIG_TEXT: Your connection is not secure
The certificate was issued for the server's hostname, for example, the hostname is webhosting-server01.example.com:
# echo 'Q' | openssl s_client -connect plesk.example.com:8443 -showcerts 2>&1 | grep =/CN=
subject=/CN=webhosting-server01.example.com
The domain name used to access Plesk UI does not match with the certificate's Common Name.
Log in using the server's hostname: https://webhosting-server01.example.com:8443.
Change the server's hostname in Tools & Settings > Server Settings > Full hostname and issue a new certificate for it according to the article: How to install or renew SSL certificate for Plesk login page?
Note: Currently it is not possible to secure Plesk UI with more than one certificate: How to use different SSL certificates for Plesk UI (over port 8443)?
1 comment
If I can log in without HTTPs forced so can others. How do I force https only?
