How to manage local firewall rules using Plesk Firewall in Plesk for Linux
11 comments
    Ehud Ziegelman
    Hi Kuzma Ivanov,
    May I ask, how come two different CLI sets, that do seem to both relate to the Plesk Fire-Wall show results that seem to be different, as below:
    systemctl status firewalld
    * firewalld.service
         Loaded: masked (Reason: Unit firewalld.service is masked.)
         Active: inactive (dead)
    systemctl status psa-firewall.service
    * psa-firewall.service - Plesk firewall module management
         Loaded: loaded (/lib/systemd/system/psa-firewall.service; enabled; vendor preset: enabled)
         Active: active (exited) since Sun 2023-04-23 18:48:45 IDT; 7h ago
       Main PID: 1017 (code=exited, status=0/SUCCESS)
            CPU: 4min 59.996s
    Notice: journal has been rotated since unit was started, output may be incomplete.
    Bragi Austfjörð
    Adding custom port doesn't work at all. I have tried both method and still unable to open a new port.
    Kuzma Ivanov
    Hello Bragi Austfjörð
    It might be that the port you opened is being filtered not by the local firewall, but an external one. It might be blocked by your hosting or Internet service provider. I'd recommend to contact them to get more information.
    Danny Clowes
    Hello, Bragi Austfjörð
    The reason the custom port options are not working as you need to disable System policy for incoming traffic to Deny all other incoming traffic for your custom rules work. WHITELIST your IP address or will lose access to your Plesk control panel.
    Ehud Ziegelman (Edited )
    I would suggest, to at first, check what you have or don't have, on the server's seen iptables for the port. Possibly Plesk would provide you the CLI to check it.
    IPTABLES is where the server stores such blocking rules.
    Also comes to my mind, a possible need to run the CLI for Plesk repair:
    plesk repair all -y
    BTW, if you are using AWS, you have control of a higher level basic firewall enabling port blocking or restricting, under 'connection'.
    Bragi Austfjörð
    I host my own servers @ home and I have used this port for a long time with CWP and many other hosting panels and the port works on other hosting panels but not for plesk, so no the port is not blocked.
    Bragi Austfjörð
    I have tried this plesk repair all -y still the same.
    Ehud Ziegelman
    Hi Bragi Austfjörð,
    What I would have done instead of you, is I REMOVE the Plesk FW using the Plesk -> Tools -> Update tool, and then reinstate it. After reinstating it, click the 'enable' and start on a new fresh beginning. I find changes Plesk recently did the the Plesk FW as likely IMHO containing Bugs (product defects). This could be related.
    What I highly recommend is the following:
    1) Obtain a  service of PRIVATE IP, for BOTH your cellular and fixed home internet connection.
    2) Set the server to use a static IP. This is possible on AWS.
    3) Write down the IPs for the above two, as well as the Server's private and public IP, and restrict on the Plesk FW almost all services (not including 'WWW server', 'DHCP client', 'Samba (file sharing in Windows networks)', 'Ping service', 'System policy for incoming traffic', 'System policy for outgoing traffic', and 'System policy for traffic forwarding' to be accessible ONLY FROM the above four IP Addresses (possibly the SSH port 22, needed also a hosting service range as in AWS light sails access which has a x.x.x.x/24 range used for this).
    4) Add the main port restriction also on the hosting level, which is a higher level from the Plesk server. On AWS LightSail they have 'networks' where you can do so.
    5) Add Google Authenticator Multi Factor Authentication (MFA) for both Plesk (using Google Authenticaiton Plesk extension), WordPress Domains (using miniorange plugin), and AWS builtin option.
    6) Scan the Plesk FireWall once in few days, to see it was not hacked to add permissions, possibly by the Plesk Installer hacked, and injection of IPs that way.
    7) Move on to set email DKIM (this is a server encryption for emails, and replace the Plesk generated key with your own), SPF (this is your declaration that email from your domain or sub domain mail.example should come only from your IPs and possibly AWS SES sending emails on your behalf) for the 4 fixed IPs you have set, and DMARC policy (this is your instruction set on a DNS record, telling other servers what to do if SPF or DKIM fail, and includes your email to receive reports) to call other servers to reject emails pretending to come from you, and found not to pass the SPF and DKIM tests.
    8) Install Fail2ban and set mail alerts.
    9) Possibly add nginx rules, to block various access according to rules and IPs.
    Best of luck!
    Tolga Altintas
    Hello Kuzma,
    to your post:
    I have the same problem. And its not filtered by something else external. Because when i turn the firewall off, i can login to ssh with my custom port. When i enable the firewall, then its not possible. We need urgently a solution for this problem!! It has to be possible, to login to ssh with a custom ssh port when the firewall is enabled.
    Support Dutiko
    Hi.
    The firewall doesn't allow custom outgoing ICMP rules.
    wich is very bad for some network specific ICMPv6 reply !
    -1
    Michel vd Lingen (Edited )
    This new Plesk Firewall system is a pain to handle through SSH, during server setup. The old version was easy to handle through SSH.
    I am trying to find a workaround, but also the import function is not working. I am now trying the following command:  /usr/local/psa/bin/modules/firewall/settings --import plesk-firewall-normal.json
    But it simply doesn't do anything, just hangs.
    The only "solution" is to do the firewall setup by hand, so manually from the Plesk interface. This is not an improvement, but a downgrade. Especially when you have to setup multiple servers. We like things automated and for 95% is completely automated, however the Plesk Firewall is a pain to deal with nowadays...
    -1
